USRP B310 (OEM)
ETTUS USRP B310 (2 TX AND 2 RX, 100MHZ, 350MHZ TO 7.2GHZ SDR), OEM CONFIGURATION
The USRP B310 OEM is a 2×2 software defined radio in a standard PCIe card format without a heat sink or faceplate. This model is designed to be used inside integrated systems.
NOTE: Do not use this model stand alone. The USRP B310 OEM is designed as a subsystem component for integration into a complete end-product. Integrators are responsible for providing enclosure, thermal management, airflow, and environmental protection appropriate for their application. For stand alone operation, please use the USRP B310 PCIe.
The NI Ettus USRP B310 is an entry-level software defined radio designed for research, prototyping, and deployment for next-generation wireless technologies. It has two transmit and two receive channels, each with up to 100 MHz bandwidth and 2 LOs for independent frequency tuning between 350 MHz and 7.2 GHz. Multi-device synchronization supports up to four B310 devices without external hardware. The B310 is available with Thunderbolt™ 3 bus for lab use and as a PCI Express plug-in card for easy system integration or native GPU coprocessing.
The USRP B310 OEM configuration is a B310 in a standard PCIe card format without a heat sink or faceplate. This model is designed to be used inside integrated systems.
Features
Features
- 350MHz to 7.2 GHz frequency range
- Up to 100 MHz Bandwidth
- 2 TX, 2 RX channel
- 2 Independent LOs
- Synchronization with built in GPSDO, 10 MHz clock reference and PPS time reference, or Multi-Device-Synchronization (8×8 without external hardware)
- PCIe plug-in card form factor
- 10 MHz and PPS reference import, GPSDO
- GPIO, JTAG control
- User-programmable AMD Kintex K325T FPGA
- USRP Hardware Driver™ (UHD) open-source software API version 4.11 or later
Block Diagram
Additional Resources
Included in This Kit:
- USRP B310 PCIe board, without heat sink
Additional Resources:
- USRP B310 Series Getting Started Guide
- USRP Hardware and Device Manual
- USRP B310 Safety, Environmental, and Regulatory Information
- USRP B310 Multi Device Synchronization Overview
- USRP Hardware Driver (UHD) API Documentation
- Latest UHD Binaries
- UHD Source Code on Github
- FPGA Resources
- AMD Kintex 7 Product Page
- App note: Bridging Prototype to Deployment: Designing Adaptable SDR Systems for Real-World RF Environments
Related Products and Recommended Accessories:
- USRP B310 (PCIe)
- USRP B310 (Enclosed)
- Multi-device sync cable
Features
- 2 Independent LOs
- FPGA Resources
- USRP B310 (PCIe)
