NI Ettus USRP X420 angled NI Ettus USRP X420
NI Ettus USRP X420 front NI Ettus USRP X420 front
NI Ettus USRP X420 back NI Ettus USRP X420 back
789917-01
QTY:
USRP X420
$52,920.00 USD
789917-01
QTY:
IMPORTANT: Please select the power cord that is compatible with your region from the list below.
QTY:
The regional power cord is a REQUIRED accessory, and is NOT INCLUDED in the kit of this product.
ETTUS USRP X420 (2 TX AND 2 RX, 1GHZ BW, 10 MHZ TO 20 GHZ, GPSDO)
The NI Ettus USRP X420 is a high-performance software defined radio for advanced wireless research, radar prototyping, and satellite communications. It offers 2 transmit and 2 receive channels with frequency coverage from 10 MHz to 20 GHz and up to 1 GHz instantaneous bandwidth.
The NI Ettus USRP X420 is a high-performance software defined radio designed for applications like prototyping radar, satellite communications, and advanced wireless communications research.  It has 2 transmit and 2 receive channels and frequency coverage from 10 MHz – 20 GHz with up to 1 GHz instantaneous bandwidth. This extended frequency range enables research in the FR3 band for 6G as well as covering important bands for non-terrestrial networks (NTN) and satellite communications. The wide bandwidth allows for a high resolution in localization scenarios for applications like integrated sensing and communications (ISAC). Each channel supports LO sharing, making the X420 an ideal platform for building multi-channel phase coherent systems.
Use the software of your choice
The NI Ettus USRP X420 is fully supported on the popular open-source USRP Hardware Driver (UHD) version 4.10.0 or later.  The USRP X420 supports open-source SDR design flows such as C/C++ and GNU Radio, as well as LabVIEW. Unlike other RFSoC-based systems, the USRP X420 is fully ready to port your previous UHD designs to take advantage of high-performance capabilities with a simple recompile.
Networked / Stand-Alone Operation
Since the USRP X420 is built on the ZU28DR RF System on Chip (RFSoC) device, it comes equipped with a quad-core ARM Cortex-A53 processing subsystem, clocked up to 1.2 GHz for stand-alone application requirements. Additionally, the RFSoC contains a dual-core ARM Cortex-R5 real-time processing unit for onboard monitoring and control.
Built-In IP
The onboard RFSoC on the USRP X420 contains more than twice the FPGA programmable logic resources than that of the previous generation X-series USRP devices. In addition, the ZU28DR comes with 8 soft-decision forward error correction (SD-FEC) hard IP cores, ideal for wireless communication systems. Given the high-speed nature of the built-in ADCs and DACs to the RFSoC, the Zynq device has 8 digital upconversion and digital down-conversion IP cores allowing for rapid in-band retuning or signal reduction.
Multi-Radio Synchronization
Multi-radio clocking and timing synchronized operation is possible with the built-in GPSDO (GPS disciplined oscillator) or with the 10 MHz reference and 1 PPS (Pulse Per Second) input signal interfaces. Multi-Radio phase-aligned and phase-coherent operations are supported, using the RF chain LO import and export functionality available on the USRP X420.
Features
Features
  • 10 MHz to 20 GHz frequency range ​
  • Up to 1 GHz Bandwidth ​
  • 2 TX, 2 RX channels​
  • Multi-channel phase coherency with independent LO sharing supported for each channel ​
  • 5G NR RX EVM of < -35 dB at 7 GHz
  • AMD Zynq UltraScale+ RFSoC ZU28DR-2
    • 12 bit ADC, 14 bit DAC
    • IQ Sample Clock rates up to 1.25 GS/s
    • Onboard SD-FEC, DDC, DUC
  • RJ45 (1 GbE) [1]
  • 10 MHz Clock reference
  • PPS time reference
  • Trig In/Out Interface
  • Built-in GPSDO
    • 2x 12 lanes via HDMI with SPI protocol support
  • 1 Type C USB host port
  • Watchdog timer
  • OpenEmbedded Linux
  • USRP Hardware Driver™ (UHD) open-source software API version 4.10.0 or later
  • RF Network on Chip (RFNoC™) FPGA development framework
  • AMD Vivado® 2021.1 Design Suite (license not included)
  • GNU Radio support  through GR-UHD, an interface to UHD distributed by GNU Radio
[1] The RJ45 port is used for remote management of the device and does not support IQ streaming.
Additional Resources
Kit Contents
  • USRP X420
  • RJ45 Ethernet Cable
  • USB-C to USB-A cable
  • Power Supply
Recommended Accessories
  • Dual 100 Gigabit Ethernet PCIe Interface Kit (PN 788216-01)
  • QSFP28 to 4xSFP28 Breakout Cable (PN 788214-01)
  • Octoclock CDA-2990
  • HDMI cable (PN 152629-01 or 152629-02)
  • HDMI Shielded AUX I/O Connector Block (PN 782444-01)
  • 3V Active GPS Antenna
Note: The USRP X420 does not support interchangeable daughterboards
Built-In IP
Features
  • RJ45 (1 GbE) [1]
  • Built-in GPSDO
  • Watchdog timer
Kit Contents
  • USRP X420
  • Power Supply
Compatible Products
This power cord allows the...
$30.00 USD
QTY:
$30.00 USD
QTY:
This power cord allows the 12...
$30.00 USD
QTY:
$30.00 USD
QTY:
$29.00 USD
QTY:
$30.00 USD
QTY:
$30.00 USD
QTY:
Compatible Products
$30.00 USD
QTY:
$30.00 USD
QTY:
$30.00 USD
QTY:
$30.00 USD
QTY:
$29.00 USD
QTY:
$30.00 USD
QTY:
$30.00 USD
QTY:
